Home › Technical datasheets
For contractors and designersTechnical datasheets for school air quality monitoring equipment
PDF datasheets for uRADMonitor MODEL A3, MODEL CITY and SMOGGIE-CO2. Each contains the sensor specifications, general characteristics and a compliance table against typical tender requirements, ready to attach to your technical offer.
PDF · 2 pages · 127 KBMODEL A3
Full station: PM1/2.5/10, CO₂, O₃, formaldehyde, VOC, noise, T/RH/P. Aluminium indoors, Stevenson shield outdoors, GSM.
PDF · 2 pages · 209 KBMODEL CITY
Urban outdoor station: PM, O₃, NO₂, SO₂, CO at 1 ppb resolution. For specifications that list traffic gases.
PDF · 2 pages · 136 KBSMOGGIE-CO2
Classroom CO₂ monitor, NDIR 400–5000 ppm, with an explanatory panel for pupils.
How to use them
From specification to technical offer
- Open the monitoring equipment section of the tender specification and list the required parameters.
- Compare them with the compliance table in the PDF. Rows marked NO show what another station in the network must cover.
- Fill in the blank rows with project-specific requirements. For unclear requirements, send us the specification and we prepare the technical answer.
- Attach the PDF to your technical offer. On delivery you receive the declaration of conformity, certificates and the commissioning record.
What each datasheet contains
Two pages, ready to attach
- Device description and its role in the school network
- Regulatory basis: EPBD Article 13 and national green school schemes
- Sensor table: range, resolution, accuracy, expected life
- Housing, dimensions, power, connectivity, operating conditions
- Independent evaluations: AIRPARIF AIRLAB, AQ-SPEC, INCD ECOIND
- YES/NO compliance table against typical requirements
- List of documents supplied at handover
A vendor-neutral reference specification is on the home page. The regulatory background is on the Regulations page.
